One piece MDF shaker style doors versus 5-piece
6/4/26
Gene Davis
Developents have occurred with CNC tooling and equipment so that a one-piece MDF door can be cut to look almost like a flat panel 5-piece shaker door. I've watched a video showing the three-bit sequence it takes to hog out the recess, then trim the perimeter of the recess, and finally to bevel that perimeter and pull the bit in a way that the corners look close to square. If you have bought and used these doors, how do they compare in cost, with the typical 5 piece doors made from paint grade wood stiles and rails and MDF centers? And how do the perform?
6/5/26       #2: One piece MDF shaker style doors ve ...
Leo G
They've also come up with a 2 pc CNC cut door. One of the problems with a one pc door is it can warp because of unevenness of the hogging out the front vs the read side. The 2 pc door solves that by cutting a frame with a rear rabbit which a panel is inserted into. Because the panel isn't cut on the face it remains stable. Only issue is it becomes a double sided process on the CNC.
I've used a few of these 2 pc doors but only as panels on refrigerators and DWs. So stability isn't really an issue since it's secured instead of hinged.
6/7/26       #3: One piece MDF shaker style doors ve ...
Matt Calnen
As a small shop, We make a five piece MDF door that I find very efficient to make. It goes real fast as there is no milling, just rip it up, run the stick profile, cut to length and you can cope without a backer because it doesn’t blow out like wood. About 20minutes a door once you have your process down, and very little sanding.
6/8/26       #4: One piece MDF shaker style doors ve ...
Lowell T Member
Website: http://cherrywoodcabinets.ca
We make our own 1-Piece HDF doors to match the 5 piece solid wood doors that we outsource. We've only been doing it about 1 1/2 years, but we've had no callbacks yet. We use 3 bits on the back, 1 1/4 pocket for back panel reveal, 1/8" downcut for panel perimeter cutout, 5mm downcut for hinge cups and hinge cup screw dowel pockets. We use 4 bits on the face, 1 1/4 pocket, 1/2" downcut for perimeter, then 1/8" downcut for perimeter squaring/cleanup, then the inside profile bit that runs up the corners to make square inside corners. We run the 1 1/4 pocket at a maximum of 4mm per trip, to get a face that needs basically no sanding. Our CNC machine time average is 6min/door, for front and back. With machining the back side like we do, it takes substantially more time, but we never have a warped door. If we were to sell our door raw to a cabinet shop, we don't know if we could sell it for much less than what we can buy maple/hdf panel doors. But there's no warping, no crack lines in the paint at the frame joints, and no groove around the edge of the panel to catch little bits of junk
