Computer Aided Design
Subject: Re: Busellato AutoCAD 2008
2/12/25
Rick Member
We have an old Busellato CNC (1999) that needs AutoCAD 2008. Does anyone have any resources for this version, or a good "work-around"?
2/12/25       #2: Busellato AutoCAD 2008 ...
Dan Member
As for and AutoCad 2008 solution your options may be quite limited.
I imagine you need AutoCad to create the layered dxf file for your Busellato. I forget the name of the software that Busellato uses.
Though, even if you find a version of AutoCad 2008 there are additional issues. Chances are that AutoCad 2008 will not run on a modern computer. As the program may be 32-bit and will not run on a 64-bit computer. Also, most new computers run Windows 10 or 11, I am not certain AtuoCad 2008 will run on Windows. An add-on program that runs on 32-bit will not run on a 64-bit version of AutoCad, unless programmed to do so. The last issue, is whether AutoDesk even allows AutoCad 2008 to be registered and activated.
Best of luck.
    • ECabinet Systems
    • The Millwork Studio
    • CabMaster Software
