Computer Aided Design
Acad 2025 angle confusion
4/19/25
I have been using auto care for quite a while but one thing that is always stumped me is, when you draw a line at a certain angle that isn’t 90, 45 or 22 1/2and then you need to draw another line off of that line at another specific angle, that isn’t 90, 45 or 22 1/2.
Usually I will go to the angle box section and type in specific angles I want it to lock onto as I rotate my mouse in a circular fashion so it populates the angle.
I get irritated doing this, because often it doesn’t draw the angle line in the direction of what I needed to be so then I end up having to mirror the line once or twice to get to the angle I needed to be.
I currently have a job that I need to draw a line that goes in the direction of the lower staircase and then to the upper staircase to outline an area underneath the stairs that I will be doing a built-in for.
As I’m standing on the stairs facing the direction of the side of the staircase going up, I’m drawing a line from downstairs heading north Northwest to the first floor and then northeast to the second floor. That angle is let’s say for example, 57° I know about the command @ (ex 25) > (enter angle) so ex- @25>57, but it rarely draws the line in the direction i want it to go. How do i determine if i subtract the angle direction i want the line to go in from 360, 180 or 90 to know what angle to type in to get it to go in the direction I want it to go so I don’t need to keep going into the field box to type in specific angles I want it to snap at and also even with that, so I don’t need to use the mirror command to get the line in the direction i want it to go
Then,
After that line has been drawn at say 23 degrees, how do i draw my next line off of that at say 149 degrees off of that line, going in the direction i want it to go?
This makes my brain hurt to think about how to do this. lol
Ty!
4/20/25       #2: Acad 2025 angle confusion ...
David Wishengrad
I have not used AutoCAD 2025, but it should be the same where a negative number goes counterclockwise and a positive number goes clockwise.
If you post some pictures or a video it might help me understand your problem better.
I typically use grip editing for such operations. I use thecopy option, which is hitting the space bar twice after activating a grip, and then pressing c for copy, then I type in the number, along with the b option for base point, if the grip I have activated is not the rotation point.
5/13/25       #3: Acad 2025 angle confusion ...
Crazy Cattle 3D
Website: https://crazycattle3d.io
You're on the right track with the @distance<angle method, but the directional aspect can indeed be tricky.
5/14/25       #4: Acad 2025 angle confusion ...
David Wishengrad
Input angle is dependant on the current UCS. Perhaps his issue has something to do with missing some of the basic understanding of the right hand rule?
The reason this thread is interesting to me is to see if they changed angle definition again at the core level.
I have seen some bugs over the years that many don't know are there and attempts at fixing them.
Perhaps Mike will toss us some screenshots. I donnot understand what he is talking about.
If we are talking on the level of the basics of inputting distances and angles at the command prompt, I have not used that feature in 20 years. It's too much typing and clicking for my taste. It works, sure, but is dependant on the UCS, and by default Acad has taken control of automating it with UCSDETECT, UCSFOLLOW and similar. I have no idea how to solve problems like this that are not addressed in any sort of timely fashion.
5/14/25       #5: Acad 2025 angle confusion ...
David Wishengrad
Mike, I think the thing you are missing is the @.
It means "relative".
If you want your input based on being relative to the noun or nouns already picked (pickfirst system variable must be correctly set), then that is your magic card to solve your probem. I am not going to show you how to use it in your particular application because I don't want you to skip over the need to understand it and be able to use it when doing other geometry modifications. I highly suggest that you turn off the dynamic input for the time being while learning to input data with relative options.
7/7/25       #6: Acad 2025 angle confusion ...
bitlife online
The current UCS determines the input angle. Maybe his problem stems from not fully grasping the fundamentals of the right-hand rule.
    • The Millwork Studio
    • ECabinet Systems
    • CabMaster Software
