Subject: Re: Stuck tool changer on SCM Record 240
7/28/24
Benjamin Weston Member
I'm trying to help an ex-employer who's operator has recently passed away unexpectedly. They have no other operators on site for this machine, which is a SCM Record 240NTTE CNC router, continuous vacuum bed, 2 spindles (2.5 axis + 5-axis Prisma head) plus multi-drilling head, and it has been at least a decade since I used it myself.
I did get it running and cut a few parts, but then had to press the E-stop when the heads were moving into machining position because I'd left a board at the back of the machine that was a collision hazard for the gantry.
The machine was changing tools in spindle 1 as it was moving to start position. The tool that was in the spindle is now in the tool changer, the spindle is empty and the tool changer is in the correct position under the spindle for the next tool.
I have 2 errors;
PLC55: NEED REFERENCE TOOL CHANGER 2
PLC54: NEED REFERENCE TOOL CHANGER 1
Does anybody know the procedure for manually changing tools, manually moving the tool changer back to it's home position, or to reset the tool changers?
    • Country Saw & Knife
    • Charles G.G. Schmidt Co.
    • Biesse America
    • Limtech Industries, Inc.
