Stuck tool changer on SCM Record 240
7/28/24
Benjamin Weston Member
I'm trying to help an ex-employer who's operator has recently passed away unexpectedly. They have no other operators on site for this machine, which is a SCM Record 240NTTE CNC router, continuous vacuum bed, 2 spindles (2.5 axis + 5-axis Prisma head) plus multi-drilling head, and it has been at least a decade since I used it myself.
I did get it running and cut a few parts, but then had to press the E-stop when the heads were moving into machining position because I'd left a board at the back of the machine that was a collision hazard for the gantry.
The machine was changing tools in spindle 1 as it was moving to start position. The tool that was in the spindle is now in the tool changer, the spindle is empty and the tool changer is in the correct position under the spindle for the next tool.
I have 2 errors;
PLC55: NEED REFERENCE TOOL CHANGER 2
PLC54: NEED REFERENCE TOOL CHANGER 1
Does anybody know the procedure for manually changing tools, manually moving the tool changer back to it's home position, or to reset the tool changers?
7/31/24       #3: Stuck tool changer on SCM Record 24 ...
rozliczae Member
To address the PLC55 and PLC54 errors on your SCM Record 240NTTE CNC router, start by power cycling the machine to reset minor errors. Then, use the manual controls to move the tool changer to its home position and perform a reference or calibration procedure via the machine’s control interface. Ensure there are no obstructions or jams and that the tool magazine is properly loaded. Consult the machine's manual for specific instructions or contact SCM support for detailed assistance if issues persist.
8/12/24       #4: Stuck tool changer on SCM Record 24 ...
HAIKol12 Member
Website: https://preisemenu.de/
To manually reset the tool changers on the SCM Record 240NTTE, you'll need to reference both tool changers via the machine’s control panel. Consult the machine's manual for exact steps.
9/26/26       #5: Stuck tool changer on SCM Record 24 ...
Anna Müller
Website: https://mcdomenu.de/
see : https://mcdomenu.de/ for complete solution.. step by step.
If you are facing issues with your CNC machine, the first step is to check the basic setup, including tool calibration, machine settings, and the condition of the cutting bits. Many problems can come from incorrect parameters, loose connections, or outdated software settings. Try running a test cut with adjusted speeds and feeds, and verify that the machine is properly aligned before making further changes. Regular maintenance and checking the controller settings can also help prevent similar issues in the future.
9/26/26       #6: Stuck tool changer on SCM Record 24 ...
David Livingstone
Website: mcdomenuusa.com
It sounds like the issue may be related to machine setup, calibration, or compatibility rather than the CNC itself. I would first check the controller settings, verify that the correct post processor is being used, and confirm that the tool offsets and parameters match the machine specifications. Also, inspecting wiring connections and running a simple test file can help identify whether the problem is mechanical or software-related. These steps usually help narrow down the cause before making any major changes.
https://woodweb.com/cgi-bin/forums/cnc.pl?read=872138
10/13/26       #7: Stuck tool changer on SCM Record 24 ...
cracker barrel
Sorry to hear about the operator. With both tool changer reference errors showing, I’d be cautious about power cycling or trying to force the changer back into position without checking the machine’s procedure first. Hopefully someone familiar with the SCM Record 240NTTE can share the exact steps to safely re-reference both tool changers. It would be great to get this machine running again without risking damage to the spindle or tool magazine. One this i noticed every in talking about foods in comments.
