Subject: Re: Carving PVC
Carving PVC
12/12/25
BH Davis  Member
I thought I'd share this interesting result I got today carving Versatex PVC with a 60° V-bit. The attached image shows a cut chart created with an Amana RC-1108 single carbide insert 60° V-bit.
I've been carving a specific sign repeatedly in my retirement shop. It's made on 3/4" PVC by applying a face mask with Oramask 813, then carving with the Amana bit, then the letters are painted, the mask removed and the face cleaned up by random orbit sanding from 220 to 600.
For the past 4 or 5 years I've been making this on Palight brand PVC. I've gotten decent carving results with the about 1/8" wide V-carved letters needing a little more attention than just a 90 psi air gun to clear out the chips left behind. The signs were 3D carved with the Amana bit a 15,000 rpm and 150 ipm feed rate.
Recently though I acquired some Versatex and to my mild dismay I found I was getting heavy chip residue in the cuts after carving. It comes out with an awl pushed along the cut but obviously this is less than ideal. So the Versatex core is different enough from the Palight to give different carving results.
Meanwhile I recently bought myself a light duty laser engraver. Even in retirement I have a few customers (not related to my old curved moulding business) and produce some things to wholesale to them plus I sell my signs. The laser engraver seemed like a nice addition to this little business.
I bring the laser into this discussion because the Lightburn software that controls it has a really nice feature I'd never seen before. When you cut a new material for the first time, just like on a CNC router, you have to determine the optimal feed rate and power levels (lasers vary the power output as vs. the the spindle rpm's). You input the minimum and maximum power you want displayed on the chart and the minimum and maximum feed rate. Then the laser produces a series of small squares that have been etched using the increasing travel speed across the bottom of the chart and the increasing power level going up the side of the chart. If you had 5 feed rates, and 5 power levels you would get 25 small squares showing the results of the intersections of the various speeds and power levels.
Well, today it occurred to me to create a similar V-groove chart in PVC to see what feed rate/rpm combination gave me the best results. I used two letters that tend to accumulate a lot of heat welded chips to the carved line: A and D. Low and behold, I didn't get the results I expected.
I would have thought a higher rpm at a lower feed rate would kept the V-bit in contact with a given point of the surface for longer, thus resulting in more heat and more heat bonding of chips to the cut surface. That though did not turn out to the the case. As you can see in the photo it was the slowest feed rate at the highest RPM that resulted in the cleanest result. Just the opposite of what I expected.
There are special bits made for cutting plastics like PVC and acrylic. There's one design I'd never heard of until recently....O-flute bits. They have a single flute with a large gullet that quickly slopes away from the cut edge. This is to give chips a quick and easy path away from the cut. I have a couple of those in 1/4" diameter (a 30° and a 60° version) but that isn't large enough to cut my sign letters without going into a stepped slope cut which is less than ideal for a number of reasons. So I called Amana tech today and asked what they had for this situation. They had no large O-flutes but they do have one particular bit designed for cutting a 60° V-groove in plastics. It is thieir 45731. Very strange looking single flute bit at about $35.00. I'll probably get one to try.
I thought this material chart was an interesting concept to apply to cutting new and different materials. It doesn't have to be a V-groove chart either. You could make a bunch of short slotted cuts with a straight bit for example to see which feed/speed combo works best on a product you've never cut before.
12/13/25       #2: Carving PVC ...
james e mcgrew  Member
I carve at 300-400 Ipm
12/13/25       #3: Carving PVC ...
BH Davis  Member
Jim,
On the approx. 1" tall letters I'm carving I'd never get up to that speed even if I set it that in my cut parameters.
Curious, what are you using for tooling?
BH
12/13/25       #4: Carving PVC ...
Your initial feed and speed would normally be the right range for soft plastics in my opinion with a chip load of .01". Maybe what is happening with the new material is that the chips are physically too large to evacuate efficiently. The smaller chips would float in the air stream. Is there any other evidence of re welding like residue built up on the bit?
I cut low density PVC Sintra with a single flute O flute with good results. I aim for a chip load of .005 - .010" depending on the diameter of the bit.
My sharpening service handed out a poster they made up with recommended cnc parameters cross referenced for tool diameter and substrate. I must remember to thank them. It has improved my cuts.
12/13/25       #5: Carving PVC ...
BH Davis  Member
Tom,
The bit remains clean after cutting.
I've seen dense packed welded chips in cuts before and this is not that bad. This stuff clears out fairly easy with an awl pushed through the V-groove. It is adhered to the cut though as vs. just dense packed.
I'm done cutting PVC for a while now so will order up that Amana bit to see what it does next time around.
Thanks,
BH
12/14/25       #6: Carving PVC ...
BH Davis  Member
If you are curious here is a screen shot for the linked video. It shows the same sort of power/speed relationship chart using Lightburn laser engraver control software.
https://docs.lightburnsoftware.com/latest/GetStarted/FirstMaterialTest/
BH
View higher quality, full size image (851 X 643)
