PCD and plywood
11/1/24
Anyone out there cutting plywood with pcd?
If so, can you share speeds and feeds.
Hard to find info.
11/2/24       #2: PCD and plywood ...
BH Davis  Member
First of all I had to look up what a PCD was..........chuckle.
Polycrystalline diamond bits
Once that was done it appeared that the diamond bits are just adhered to a carbide slip so it seems the net result is a bit that would cut like a similar carbide bit.
So even though the longevity might be greatly enhanced I'd think you would use the same feeds and speeds as a comparable carbide tipped bit. No?
BH
11/14/24       #3: PCD and plywood ...
Z Member
Spent lots of time and even more money trying to get pcd bits to work better than carbide.
It never happened. They are not worth it for plywood.
If you really want to get better tooling and know what you’re ordering then you need to research the cobalt percentages.
QIC.tools have amazing products and an even better reputation in terms of quality. Vortex, LMT, white side, amana, etc etc etc all don’t care.
Qic tools stand by their products.
