Subject: Re: Waterborne clear over steel
4/14/22
Mark B
Running a bunch of furniture mix of wood and steel. Steel is getting a black acid patina (water based as well). Initial samples we just patina'd the steel, torch dried it thoroughly and shot a couple coats of waterborne CV to give it a sheen. I had thought there would be an issue with the waterborne over steel but weeks later the samples look great. We had initially planned on running solvent clear over the steel but most of the steel clears are just overpriced nitro so at this point were thinking of just staying with the waterborne. Have a call in to mfr. regarding anything long term that were missing but thought you all may have some input.
I have more faith in the durability over nitro for sure and would love to stay away from solvent.
4/14/22       #2: Waterborne clear over steel ...
If there is any raw steel on the edges or corners, it will rust. I'd suggest a sealant layer of shellac before the water based top coat.
4/14/22       #3: Waterborne clear over steel ...
Mark B
Rich,
That was my concern as well from the onset. Sample shows zero after weeks of semi harsh treatment with zero backside coating so there are dead raw areas exposed to the coating.
View higher quality, full size image (2515 X 1174)
View higher quality, full size image (2391 X 1116)
4/14/22       #4: Waterborne clear over steel ...
Mark B
P.S.
Those are images of the same sample weeks old patina clear and raw back
4/14/22       #5: Waterborne clear over steel ...
They started using waterborne(water cleanup) paints for metals over solvent many years ago. The military uses some very high zinc content ones on steel in marine locations that significantly last longer than oil/solvent, because they bond better.
The adhesiveness of some waterborne products definitely exceeds the other products. My favourite is Bullseye 123 primer. If you leave it in a paint tray for a day, good luck removing it even letting it soak in water. Likewise getting it off of glass is a pain.
The key is the better waterbornes have virtually no water in the formula. They are water soluble when liquid and can be cleaned up with water, but after that they stick like the big time.
