Subject: Re: Sun faded walnut kitchen
7/6/24
Matt Member
I have a two year old sun faded walnut kitchen to work on. It is sprayed with lacquer and nothing else. The customer would like to have the dark brown returned.
What are my options at this point to return the deep brown color?
Starting new to help this would be boiled linseed oil first, or a burnt umber tint then the lacquer. But I am looking for a way to fix what is already there.
7/9/24       #3: Sun faded walnut kitchen ...
tom gardiner
Without stripping the kitchen entirely your option is to spray shader and then clear coat. You will have to know the original finish to make sure you spray a compatible top coat.
Test one piece first through all the steps to be sure it will adhere and you can master a consistent shading tone.
7/9/24       #4: Sun faded walnut kitchen ...
I would agree with Tom, word for word actually.
We tried that a few years ago and had the same results you are talking about, we then tried staining with a natural color first and that solved the problem.
The coatings now are so much better so there are some coatings that don’t change much over time.
