Sun faded walnut kitchen
7/6/24
Matt Member
I have a two year old sun faded walnut kitchen to work on. It is sprayed with lacquer and nothing else. The customer would like to have the dark brown returned.
What are my options at this point to return the deep brown color?
Starting new to help this would be boiled linseed oil first, or a burnt umber tint then the lacquer. But I am looking for a way to fix what is already there.
7/9/24       #3: Sun faded walnut kitchen ...
tom gardiner
Without stripping the kitchen entirely your option is to spray shader and then clear coat. You will have to know the original finish to make sure you spray a compatible top coat.
Test one piece first through all the steps to be sure it will adhere and you can master a consistent shading tone.
7/9/24       #4: Sun faded walnut kitchen ...
I would agree with Tom, word for word actually.
We tried that a few years ago and had the same results you are talking about, we then tried staining with a natural color first and that solved the problem.
The coatings now are so much better so there are some coatings that don’t change much over time.
7/24/24       #5: Sun faded walnut kitchen ...
Frank Garrido Member
Website: http://www.cabinethero.com
If the original finish top coat is solvent base lacquer a penetrating dye with retarder if done correctly should penetrate sun-faded areas to restore the original color ton. I have done this multiple times. especially on Mohagany, walnut, and other woods that natural wood tones get affected by sunlight. Testing a section is
really important in knowing how to use a penetrating dye stain to help store the original color. the combination of a universal retarder and the dye stain will let you observe the wet look tone and as the
retarder dries the penetrating dye reaches deeper into the original coating and wood, this is where the original ton can be restored. A small test spray with clear lacquer can be done in an area to see how many coats of dye with retarder combinations are needed. The mix of retarder to dye should be 50/50 if stain or more retarder if the dye stain is too strong. Acetone can also be used to dilute dye stains but don't use too much because the stain will dry too quickly and not penetrate. It will take a few passes so be patient. Once a small test area with a clear finish confirms the desired tone, it is ready to be seald or top coated with clear Lacquer.
7/24/24       #6: Sun faded walnut kitchen ...
retarder dries the penetrating dye reaches deeper into the original coating and wood, this is where the original ton can be restored. A small test spray with clear lacquer can be done in an area to see how many coats of dye with retarder combinations are needed. The mix of retarder to dye should be 50/50. More retarder can be used if the dye stain is too strong. Acetone can also be used to dilute dye stains but don't use too much because the stain will dry too quickly and not penetrate. It will take a few passes so be patient. Once a small test area is sprayed with a clear finish and confirms the desired tone, it is ready to be sealed or top coated with clear Lacquer.
