Getting rid of pink color in alder
9/24/20
Nick Cook Member
Website: http://kootenaicabinets.com
I'm trying to get a cappuccino color (light brown) on alder and I keep getting the pink or red coming back through when we add clear lacquer. I'm attempting this with a water base spray stain. Any good tricks for killing the red in clear alder. These are veneer slab doors from Northern Contours.
9/24/20       #2: Getting rid of pink color in alder ...
Add some yellow-green dye to kill off the pink. Very small amount in the clear.
9/25/20       #3: Getting rid of pink color in alder ...
Nick Cook Member
Hi Leo,
Do you mean add it to the clear lacquer?
9/25/20       #4: Getting rid of pink color in alder ...
Yes, that's what I meant. But in reality you might be able to add it to the stain too. If you do that it'd likely be a better experience all around. You won't have a odd tint to the clear. But it doesn't always work in the stain. It always works in the clear. Be sure not to over do it though in the clear or you'll see the cast of the color.
9/25/20       #5: Getting rid of pink color in alder ...
Nick Cook Member
Ok thanks Leo, I'll do some experimenting.
9/25/20       #6: Getting rid of pink color in alder ...
Shane Welch
Mohawk green dye M520 1/4 oz. of dye to 32 oz. of stain...... use a cup gun or pressure pot and make passes on the substrate to cover the panel evenly with this dye mixture.... This light mix should neutralize the perception of red poking through within one or two passes...strenthen or weaken the mixture as needed... then do your regular schedule of color..... samples samples samples!
9/27/20       #7: Getting rid of pink color in alder ...
Bart
I've done this a half dozen times on alder. I use GF's WB green dye heavily diluted with H2O and spray it on. Let it dry and then stain. Or you could seal with a spit coat/sand and then stain especially if it's a light or mid tone color you're looking for. Samples for sure.
my2cts
9/27/20       #8: Getting rid of pink color in alder ...
Shawn Turner  Member
Website: specializedfinishes.com
All of the responses above are solid solutions.
I am a fan of the yellow concentrated universal dye from Wurth or Sherwin mixed with whatever sealer I am using or just water, or lacquer thinner, about .5oz per gallon if-ish. You will be surprised at the results. some dyes look yellow but are leaning on the green side. So if something says yellow oxide expect it to lean red.
If you do not have dye available you can use tint. But, tint is made of particulate matter so it will often very subtly flatten your layers of color in wood grain to some degree.
Otherwise go OLD SCHOOL!!! XD
Oxalic acid, A&B Bleaches, homeowner wood brighteners.
Follow those direction and do not get it on anything you do not get it on or in your skin, eyes, mouth yadda yadda. Follow all safety precaution that will be found on the back of the product container.
Once again my disclaimer. There are other dyes available on the market.
I am not pushing Wurth Lewis or M.L. Campbell one bit. Do not get me started about Sherwin Williams.
Compare products and try to buy locally if possible. ALWAYS!
Always read the back of the can!
View larger image
Woodsong II Microton Spray Dye Stain
9/28/20       #10: Getting rid of pink color in alder ...
Shane Welch
I messed up my suggested formula.. I meant 1/4 oz. of green mohawk M520 to 32oz. of acetone... Several even passes of this weak mixture on raw wood will shift the color enough to be workable. Lemon yellow could also be a mohawk option as it it a yellow/green.... we use this technique a lot to even out substrates to the same playing field before we go into regular stain procedures.... taking care of sap lines... differences in varied color...(using different colors as necessary) get it fairly even at the raw wood stage and then proceed to bring the main color up to snuff...
