Chemcraft AQUASET on re-finished aristokraft sarsaparilla?
1/7/25
Saul Goldstein Member
Hello, fellow wood-philes!
We currently have Aristokraft Sarsaparilla cabinets (dark brown) and are hoping to get new cabinet doors while resurfacing/painting the boxes to achieve a milky, lighter green look (reference photo attached). In our household, being toxin-free is very important, and we came across Chemcraft AQUASET (initially, we considered The Real Milk Paint, but we were told it wouldn’t achieve the look we desire and would not adhere.) However, some have suggested that AQUASET paint yellows over time, chips easily, lacks durability, and may not guarantee a long-lasting finish. Any thoughts or suggestions on other options?
TYIA!
View higher quality, full size image (1170 X 2532)
https://https://chemcraft.com/en/products/waterborne/423-27xx-aquaset-wb-pigmented-tc
1/7/25       #2: Chemcraft AQUASET on re-finished ar ...
Jonathan Mahnken
Aquaset is a good and durable product. clean and sand first. then prime with Aquaprime stainblocking primer 2 coats. then the aquaset. Airless with a 308 tip is a good choice.
1/12/25       #3: Chemcraft AQUASET on re-finished ar ...
Thank you so much for sharing your insights, Jonathan!
1/15/25       #4: Chemcraft AQUASET on re-finished ar ...
Bart
I've used Ben Moore Command 5 times. 4 for refinish where it excels and 1 on raw. It doesn't sand so well but for a refinish I would have no problem recommending. It sticks to anything and no priming.Very durable. Dries fast and covers great. 2 coats would do it. They say it's possible to brush but I sprayed it slightly thinned w/gravity gun. If you can handle an airless w/fine finish tip that's a good way to go.
