Wood NetWork
Subject: Re: Shaping Question
Shaping Question
11/5/22
Kevin Gibbs
I need help using full surface insert cutter heads, specifically on cabinet door edges. What is the best method? I am familiar with using a outboard fence, but how to surface the edge of the doors with full face cutters.
11/6/22       #2: Shaping Question ...
Bruce H
set up the out feed fence in line with the cutter and the in feed fence to take off the amount you want. a block at the back of the door may help in preventing tear out.
11/10/22       #3: Shaping Question ...
David Sochar Member
Outboard fences are fussy and you have the change them for every size of door.
Set it up with offset fences as Bruce suggests, and you effectively have a jointer - a profile jointer if you will. The only blowout might be the last corner, and a block can prevent that.
11/15/22       #4: Shaping Question ...
KGibbs Member
Thanks for you input! Helping me come up to speed.
What is the purpose of zero clearance aux fences? Are there any other methods used for full face cutters?
11/26/22       #5: Shaping Question ...
Joe Calhoon Member
Zero clearance sub fences can close the opening between the fence halves when removing the entire edge of a frame. Especially helpful for narrow or small frames.
The pictures show one that is made to remove 1 mm from the edge same as using the split fences offset.
Mine are not totally zero. I usually just try to close the opening to 2 1/2 to 3”. Easy to make with motorized or handwheel controlled fences. Use caution with non pinned fences. Rough cut close with a jig saw.
The pictures with the yellow fence is using a 8” diameter cutter to outside profile 3” thick windows. The fence opening would be huge with the normal fence.
    Excel Wood Products
    • J&P Machines
    • CabMaster Software
    • Lignomat
